Siebel Hospitality Guide > Generating Event Checks > Process of Generating Event Checks >
Generating Trial Checks
When a trial check is generated, an event check total is calculated for the selected event order that includes taxes and service charges. Generating a trial check allows the operations manager to review and update order details before the final event check is generated and posted. A trial check can be generated multiple times before, during, and after the event. However, the trial check can only be generated before an event check is opened. This task is a step in Process of Generating Event Checks. To generate a trial check
- Navigate to the Service Orders screen, then the Event Order view.
- In the Event Orders list, query for and select the event order.
- In the Event form, click Trial Check.
One or more event checks are generated for the selected order. For more information about the resulting event checks, see About Generated Event Checks.
