Siebel Object Interfaces Reference > Using Siebel Visual Basic and Siebel eScript > Configuring Error Handling >
Opening the Siebel Script Editor
This topic describes how to open the Siebel Script Editor. To open the Siebel Script Editor
- In Siebel Tools, in the Object Explorer, click the object type you must modify.
For example, click Applet.
- In the Object List Editor, locate and then right-click the object you must modify.
For example, in the Applets list, locate and then right-click Contact List Applet.
- In the Scripting Language dialog box, choose one of the following menu items:
- Edit Server Scripts
- Edit Browser Scripts
- In the Scripting Language dialog box, choose Visual Basic or eScript, and then click OK.
