Siebel Object Interfaces Reference > Using Siebel Visual Basic and Siebel eScript > Configuring Error Handling >
Using Script to Add Business Logic to a Business Component
You can use Server Script or Browser Script to add business logic to a business component. To use script to add business logic to a business component
- Open the Siebel Script Editor.
For more information, see Examples of Using Siebel Visual Basic and Siebel eScript.
- In the navigation tree of the Siebel Script Editor, choose an event in the BusComp Tree.
- In the Siebel Script Editor window, write your script.
- Choose the Debug menu, and then the Check Syntax menu item.
The Check Syntax menu item is available only for Server Script.
- Save the modifications.
- Choose the Tools menu, and then the Compile Selected Objects menu item.
- Choose the Debug menu, and then the Start menu item.
