| Siebel CRM Partner Relationship Management Administration Guide Siebel Innovation Pack 2016 E24800-01 |
![]() Previous |
![]() Next |
View PDF |
Siebel PRM uses one home page for public, individual and registered users. Views on the home page are hidden or displayed based on the user's login to personalize the home page for each different type of user.
When you create your home page, you must control which views and content are displayed to different types of users.
Personalization rules control whether views are hidden or displayed. Personalization is based either on global variables or on profile attributes, depending on whether the user is anonymous, self-registered or registered. For example, personalization uses a global variable to determine whether the user is anonymous.
Other personalization rules use profile attributes to determine whether the user has a position or not. For example, the Program Information view appears if the user is anonymous.
Other personalization rules used in the salutation can be based on many other profile attributes, such as the user's organization or geography. For more information about personalization, see Siebel Personalization Administration Guide.
