| Siebel CRM Partner Relationship Management Administration Guide Siebel Innovation Pack 2016 E24800-01 |
![]() Previous |
![]() Next |
View PDF |
After the partner program has been set up, and the partner application has been created, the partner can use the PRM Portal to apply for membership to the program.
Partners who are not registered for partner programs can apply to partner programs on the PRM Portal as well as those who have already registered meaning the partners have some visibility to the program).
The fields that the partner must complete depend on the SmartScript or external application used when you set up the application, as described in "Setting Up Partner Program Applications".
A partner employee might apply for membership to a program after another employee of the same partner company has already applied for membership to the same program. If the first application from that company has already been approved, an error message is displayed to the second partner who applies. If the first application has not yet been approved, an error message is not displayed and there are two application from the same partner company. However, even if the brand owner approves both applications from the same partner company, only one Program Membership record is created for that partner company, so there is not a problem of duplicate memberships.
The following procedure allows partners to apply to a partner program.
To apply as a partner
Log in to the PRM Portal and navigate to the Partner Programs screen.
Select the program you are interested in.
Click Apply, and complete the fields in the application.
Note: Make sure you are not currently a member of this partner program. If you are already a member, you are not allowed to apply again. |
It the partner selects the Use Agreement Item Dates check box on the application header, then start and end dates for the membership are set to the same as the start and end dates of the agreement associated with the program.
To check the status of your application, navigate to the Program Applications screen and query for the application.
