Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Interact with Conflicts and Messages >
GetSignals Method
This method retrieves configuration engine signals.
Input Arguments
  • ObjId. The unique identifier of the complex object root (for example, Quote ID).
  • RootId. The unique identifier of the complex object root (for example, Quote Line Item row Id).
  • (Optional) Path. The integration ID where the item gets signals.
  • (Optional) Version. Version arguments are used only when testing a customizable product version that is different from the currently released version.
Output Arguments
The property set returned will have child property sets, as follows:
<Signal Expl="signal"/>
Siebel Product Administration Guide Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices.
