Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs to Set Product and Attribute Values >
GetLinkItemValues Method
This method retrieves the linked item values. Use it as follows:
- Clear the cache values if specified by the caller.
- For the search specification set by the caller:
- If only RootProductId is given and no child property sets are given, try to find only the values for LinkItems that are under the given RootProductId.
- If both RootProductId and Child Property Sets are given, try to find only the values for LinkItems that are defined in the child property sets.
Input Arguments
- ClearValues. Y or N. Clears all cached Link Item Values.
- GetAllValues. Y or N. Gets all values from the cache or only the values passed in for the search specification.
- RootProductId. Root Product Id.
- LIVersionId. Root Product Version Id (optional).
- Child Property Set (0) Type: LinkedItem:
- ProductId. Product Id
- VersionId. (optional) Version Id
- InClass. Y or N.
- LinkItemId. Link Item Id
- Child Property Set (1) Type: LinkedItem:
- ProductId
- VersionId (optional) Version Id
- InClass. Y or N.
Output Arguments
Each linked item is returned as a child property set as follows:
- Child Property Set Type: LinkedItem:
- CxLnkItmId. Link Item Id.
- CxLnkItmName. Link Item Name.
- CxLnkItmDesc. Description.
- CxLnkItmDef. Definition.
- CxLnkItmIsActive. IsActive Flag.
- CxLnkItmValue. Value.
- CxLnkItmDisplayValue. Display Value.
- CxLnkItmType. Type.
- CxLnkItmProductId. Product Id where this linked item is defined.
- CxLnkItmVersionId. Version Id of the previous product.
