Siebel Product Administration Guide > Siebel Configurator API Reference > Instance APIs for the Complex Object Manager >
UnloadInstance Method
This method removes the existing configuration session from memory. It must be called after synchronizing the instance at the end of the configuration session.
Input Arguments
  • ObjId. The unique identifier of the complex object header.
  • RootId. The unique identifier of the complex object root.
  • IntObjName. The name of the integration object that was used to load the instance.
Output Arguments
None.
Siebel Product Administration Guide Copyright © 2017, Oracle and/or its affiliates. All rights reserved. Legal Notices.
