Siebel Product Administration Guide > Configuration Constraints > About Managing Configuration Constraints >
Editing Configuration Constraints
In the Constraints List, you cannot edit the definition of the constraint in the Constraint column. To edit the definition, you must display the constraint in the Constraint Statement form, make your changes, and save the constraint. When you save the constraint, you can overwrite the constraint with the changes or save the changes as a new constraint. The following procedure explains how to edit a constraint definition and overwrite the constraint with the changes. To edit a constraint
- Navigate to the Administration - Product screen.
- Select and lock the desired customizable product or product class.
- Navigate to the Constraints view.
In the Constraints list, select the desired constraint.
- From the Constraints list menu, select Edit Constraint.
The Constraint Statement and "Insert a" tabs appear.
- Edit and save the constraint.
- From the Constraints List menu, select Validate.
This starts a configuration session. Verify that the edited constraint works correctly.
