| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2016, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
It is strongly recommended that you implement Transport Layer Security (TLS) encryption for all of the following services and communication paths in a Siebel CRM implementation:
For communications between Siebel Web server and Siebel Web Client.
For communications between Siebel Server and the Web server.
For encryption of SISNAPI communications between Siebel Enterprise components, for example, communications between the Siebel Server to Siebel Web server (SWSE), or between Siebel Servers.
For communications between an LDAP or ADSI security adapter and a directory server.
For communications using the Siebel Business Applications external interfaces (EAI), which use Web services to send and receive messages over HTTP.
For communications between Siebel Server and an email server, including encryption for SMTP, IMAP, and POP3 sessions between Siebel Server and an email server.
For Oracle WebLogic server integrations with, for example, Oracle BI Publisher.
For more information, see "Enabling Transport Layer Security for Oracle BI Publisher Running on Oracle WebLogic Server".
For more information about the support for TLS encryption provided by Siebel CRM, see 1944467.1 (Article ID) on My Oracle Support. For more information about configuring security in Siebel CRM, see "Roadmap for Configuring Security".
Note: To ensure that you are using the highest level of security, download and install the latest Innovation Pack and patchset release to enable the highest level of security and obtain the latest security-related patches. For more information on this, see Siebel Installation Guide for the operating system you are using and Siebel Patchset Installation Guide for Siebel CRM (1614310.1 Article ID on My Oracle Support). |
