| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2016, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
This topic describes how to set up encryption for communication between components in the Siebel environment. Encryption can be configured for data traffic between the Web server, Siebel Server, and Siebel Web Client.
To configure secure communications in your Siebel environment, perform the following tasks, as appropriate for your environment:
"Configuring TLS Encryption for a Siebel Enterprise or Siebel Server"
"Enabling TLS Acceleration for Web Server and Web Client Communications"
"Configuring Encryption for Mobile Web Client Synchronization"
The encryption options described in this topic are not used to encrypt data in the database. For information about data encryption, see "About Data Encryption". Also, these encryption options are not used for communications with the database; for such encryption, check with your database vendor.
