| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2016, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
This topic contains information for Siebel Financial Services applications that differs from information in other topics of this guide, or that otherwise warrants mention. For more information about user authentication for Siebel Financial Services applications, see the following topics:
Security adapter authentication is a prerequisite if you want to implement self-registration or external administration of users. However, not all Siebel Business Applications provide self-registration and external administration of users as default functionalities. For information about the applications in this group that provide self-registration and external administration of users as default functionalities, see "User Registration and Administration for Siebel Financial Services".
Implementation of LDAP or ADSI security adapter authentication is the same for Siebel Financial Services applications as described in other topics in this guide, with the following exceptions. Parameters for Siebel Financial Services applications are listed primarily in the eapps_sia.cfg file. The eapps.cfg file is also included, as documented in other topics in this guide. The eapps.cfg file has an include line that points to the eapps_sia.cfg file. References throughout this topic to the eapps.cfg file refer to the eapps.cfg file and the eapps_sia.cfg file.
The Responsibility and New Responsibility that are assigned to the seed anonymous user GUESTCST are intended for use with Siebel Financial Services customer applications. These responsibilities differ from the responsibilities assigned to GUESTCST for Siebel customer applications that are not specific to financial services, as documented in other sections of this guide.
If you deploy either Siebel Events Manager for Finance or Siebel customer applications that are not specific to financial services concurrently with any other Siebel Financial Services customer applications, then you must create a separate anonymous user.
The new anonymous user is used for Siebel Events Manager for Finance and for the Siebel customer applications that are not specific to financial services; that is, the applications documented in other sections of this guide. Assign responsibilities to this anonymous user as they are documented for GUESTCST in Appendix B, "Seed Data."
When you add TESTUSER to the database, specify values for the Responsibility and New Responsibility fields that are appropriate for a typical registered user for the application you are setting up. For information about the seed responsibilities provided for specific applications, see "Seed Data for Siebel Financial Services" and Appendix B, "Seed Data.".
Implementation of Web SSO authentication is the same for Siebel Financial Services applications as described in other topics in this guide with the following exceptions.
Parameters for Siebel Financial Services applications are listed primarily in the eapps_sia.cfg file. The eapps.cfg file is also included, as documented in other sections of this guide. The eapps.cfg file has an include line that points to the eapps_sia.cfg file. References throughout this topic to the eapps.cfg file apply to the eapps.cfg file and the eapps_sia.cfg file.
The new anonymous user is used for Siebel Events Manager for Finance and for the Siebel customer applications that are not specific to financial services; that is, the applications documented in other sections of this guide. Assign responsibilities to this anonymous user as they are documented for GUESTCST in Appendix B, "Seed Data.".
In addition to the eapps.cfg file, the Siebel Web Engine also uses the eapps_sia.cfg file to control interactions between Siebel Financial Services applications and the Siebel Web Engine. The section defining the Application Object Manager and authentication parameters for an application appears once, in either the eapps.cfg file or in the eapps_sia.cfg file.
Table C-2 lists the sections in the eapps.cfg and eapps_sia.cfg files that are provided for Siebel Financial Services applications.
Table C-2 Sections in eapps.cfg and eapps_sia.cfg Files
| Tools Application Object Name | Section in eapps.cfg | Section in eapps_sia.cfg |
Siebel Financial Services |
None |
[/fins] |
Siebel Financial Services ERM |
None |
[/finserm] |
Siebel Marketing |
[/marketing] |
Not applicable |
Siebel Financial PRM |
None |
[/finsechannel] |
Siebel eBanking |
None |
[/finsebanking] |
Siebel Financial eBrokerage |
None |
[/finsebrokerage] |
Siebel Financial eService |
None |
[/finseservice] |
Siebel Financial eEnrollment |
None |
[/finseenrollment] |
Siebel FINS eSales |
None |
[/finsesales] |
Siebel Financial eCustomer |
None |
[/finsecustomer] |
Siebel eEvents for Finance |
[/eevents] |
None |
For names of application configuration files for specific applications, see "Configuration File Names for Siebel Financial Services Applications".
