| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2016, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
Table B-2 describes nonemployee user records provided as seed data. Default passwords are not provided for these records. If you use a seed user record as the anonymous user record, then you must set the AnonUserName parameter to the seed user ID (for example GUESTCST) when configuring the SWSE, or set it manually in the eapps.cfg file. For information on configuring the SWSE, see Siebel Installation Guide for the operating system you are using. For information on manually setting passwords for the anonymous user, see "Encrypted Passwords in the eapps.cfg File".
Table B-2 User Seed Data Field Values
| Last Name | First Name | User ID | Responsibility | New Responsibility | Used by These Applications |
Customer |
Guest |
Web Anonymous User |
Web Registered User |
Customer applications |
Channel Partner |
Guest |
Unregistered Partner Agent |
Self-registered Partner Agent |
Siebel Partner Portal |
