| Siebel CRM Siebel Security Guide Siebel Innovation Pack 2016, Rev. A E24814-01 |
![]() Previous |
![]() Next |
View PDF |
You can configure Siebel Business Applications to specify whether or not URLs must use TLS over HTTP (HTTPS protocol) to access views in a Siebel application. You can specify that HTTPS must be used to access specific views, to access all views, or is not required to access views.
If you use the HTTPS protocol, then Your Web server must be configured to support HTTPS. You must install a certificate file on the Web server with which you want to secure communication. For more information, see "About Certificates and Key Files Used for TLS Authentication".
The value (True or False) of the SecureBrowse component parameter determines whether or not the Siebel Web Engine verifies that requests for a view use the HTTPS protocol. You can specify a value for the SecureBrowse parameter to indicate whether or not the HTTPS protocol must be used to access all the views in an application
The following procedure describes how to configure your application to use HTTPS or HTTP for all views in an application.
To configure your application to use HTTPS or HTTP for all views
Using Siebel Server Manager, specify one of the following values for the SecureBrowse component parameter:
SecureBrowse is set to TRUE. If SecureBrowse is set to TRUE, then HTTPS is required for all views in the application, regardless of how the Secure attribute is set for individual views.
SecureBrowse is set to FALSE. If SecureBrowse is set to FALSE, then HTTP is required for all views in the application, except for views for which the Secure attribute is set to TRUE. Secure views require HTTPS.
Note: In previous releases of Siebel Business Applications, values for the SecureLogin and SecureBrowse parameters for Siebel Web Clients were specified in the Siebel application configuration file. Since Siebel version 8.0, SecureLogin and SecureBrowse are Application Object Manager (AOM) parameters which are set using Siebel Server Manager. For information on setting parameters using Siebel Server Manager, see Siebel System Administration Guide. |
You can also specify that user credentials entered at login must be transmitted from the Web client to the Web server using the HTTPS protocol by setting values for the SecureLogin parameter. For information on this parameter, see "Implementing Secure Login".
Note: If you set SecureLogin to True and SecureBrowse to False as object manager parameters, then you must also set EnableSecureCookie to False in the [SWE] section of your eapps.cfg file. If you do not do this, then the cookie from invoking the login view via HTTPS will not be used for the subsequent HTTP requests. As a result, a new non-secure cookie will be set requiring you to log in for a second time. |
