Siebel Database Upgrade Guide for DB2 for z/OS > Performing Postupgrade Tasks on the Target Database >
Activating New License Keys After an Upgrade
Upgrades: All upgrades.
Environments: All environments.
This topic is part of an upgrade process. See How to Perform a Siebel Database Upgrade.
In Siebel Innovation Pack 2016, the license keys for Siebel CRM base applications that were previously provided in seed data in the Siebel database are inactive. License keys entered by customers are unchanged. A new utility is provided for activating or deactivating the license keys that you require. You run the License Key Activation utility after installing a new Siebel database, running Incremental Repository Merge (for migration installations), or completing a full database upgrade.
You can find license key information for Siebel Business Applications at Oracle's license codes site.
For the Siebel license keys, see
http://licensecodes.oracle.com/siebel.html
The License Key Activation utility is supported on all operating systems and databases for Siebel
Business Applications.
To start the License Key Activation utility
  1. On the computer where you installed Siebel Server, navigate to the following location:
    SIEBSRVR_ROOT\bin
  2. Run the following program, according to your operating system:
    • Microsoft Windows: licensekeymodule.bat
    • UNIX: licensekeymodule.sh
  3. In the License Key screen, enter valid data for the following fields:
    1. In the Siebel Server Location field, enter the installation path for Siebel Server.
    2. In the ODBC DSN field, enter the ODBC data source for the Siebel Database.
    3. In the Table Owner field, enter the table owner for the Siebel database.
    4. In the Username field, enter the user name for logging into the Siebel database.
    5. In the Password field, enter the password for logging into the Siebel database.
    6. In the DB Platform field, enter the RDBMS type: IBM DB2, Microsoft SQL Server, or Oracle Database.
    7. In the Log Folder field, enter the folder in which the log file licenseKeys.log is created. This log file shows database connection information for troubleshooting purposes, and lists all of the license keys that were activated or deactivated in each session.
  4. Click Login.
    The license key activation screen appears, which lists Siebel CRM license keys.
  5. For each license key module whose activation status you want to change, click the Active Flag check box to activate or deactivate this license key.
  6. To apply your selections to the Siebel database, click Apply. Or, to reset any changes you have made in this screen, or since you last clicked Apply, click Reset.
    CAUTION:  After you have clicked Apply, the Reset button does not reset activation settings to their original state. However, you can change the activation status and click Apply again.
  7. To exit the utility, click the X in the top right corner.
For more information on installing license keys, see Siebel Installation Guide for the operating system you are using and Siebel Applications Administration Guide.
Siebel Database Upgrade Guide for DB2 for z/OS Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices.
