Siebel Database Upgrade Guide for DB2 for z/OS > Basic Database Preparations for a Siebel Upgrade > Verifying Database ConfigurationEnvironments: All environments. Verify that your development Siebel database configuration meets or exceeds Siebel requirements as described in Implementing Siebel Business Applications on DB2 for z/OS. Be aware of the following:
Before you begin your upgrade, verify your database configuration. The consequence of exceeding available resources is a halted upgrade that requires you to allocate time to adjust the environment and then resume the upgrade. Before you begin an upgrade or Incremental Repository Merge, you must have a default WLM environment defined for the DB2 subsystem. When you upgrade from a previous version of Siebel Business Applications to the current release, the size of your database is likely to increase. The amount by which your database grows might vary widely, depending on your database configuration, row size of tables, and data content. For information on estimating the growth, see About Estimating Database Size. The growth percentage will also increase depending on how you size your database and configure default storage for database table spaces. For example, if you set the default storage for your initial or next extent in a given DB2 table space to 10 KB, that table space will grow by a smaller percentage than if you set it to 100 KB. |
| Siebel Database Upgrade Guide for DB2 for z/OS | Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
