Using Siebel Tools > Using Siebel Script Editors > Using the Siebel Debugger >
Accessing the Siebel Debugger
You can access the Siebel Debugger. To access the Siebel Debugger
- Do one of the following:
- Open the Siebel Script Editor, set a breakpoint in your script, and then click the Start button.
For more information, see Using Breakpoints.
- Run a script that includes a run-time error.
If a script includes a run-time error, then Siebel Tools suspends the script, starts the Debugger, and highlights the line that includes the error. An unhandled Siebel VB or eScript error is an example of a run-time error.
