Using Siebel Tools > Using Siebel Script Editors > Using the Siebel Debugger >
Using the Calls Window
The Calls window includes a list of subroutine and function calls that Siebel Tools runs prior to the current code line. To use the Calls window
- Open the Siebel Script Editor.
- Click the Calls button in the Debugger toolbar while you run the Debugger.
Each line in the Calls window represents a subroutine that Siebel Tools entered but did not complete. If you choose an entry in this list, then the following occurs:
- The Debugger window displays the line of code that makes this call.
- The Variable window displays the variables that are associated with the procedure that makes the call.
