Using Siebel Tools > Using Siebel Script Editors > Using the ST eScript Engine >
Setting Options for the ST eScript Engine
This topic describes how to set options for the ST eScript Engine.
To set options for the ST eScript Engine
  1. Make sure the ST eScript Engine is enabled.
    For more information, see Enabling the ST eScript Engine.
  2. In Siebel Tools, click the View menu, and then click Options.
  3. In the Development Tools Options dialog box, click the Scripting tab.
  4. To define the options in the Engine Settings section, use the information in the following table. It is recommended that you enable all of these options.
    Option
    Description
    Enable Warnings
    If this check box includes a check mark, then Siebel Tools displays script compile warning messages. For information, see About ST eScript Engine Warnings.
    Deduce Types
    If this check box includes a check mark, then Siebel Tools deduces the type of local variables. For more information, see How the ST eScript Engine Determines the Type of Variables That a Script Uses.
    Fix and Go
    If this check box includes a check mark, then Siebel Tools allows you to test and debug your script without compiling. For more information, see Using Fix and Go.
Using Siebel Tools Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices.
