Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools >
Opening Existing Workspaces
You must open a workspace before you can make any configuration changes. Remember that you can open only one workspace at any given time within your current session.
- If you are the owner of the opened workspace, then you can edit (read and write) that workspace.
- If you are not the owner of the opened workspace, then you can only read (without editing) that workspace.
Opening a workspace sets a session-level workspace context; therefore, while the workspace is opened, all configuration changes that you made are saved as parts of the opened workspace. To open an existing workspace
- In the workspace dashboard, navigate to the Workspace explorer pane.
- Select the workspace that you want to open and then right-click.
A list of available options appears. These options are Open, Delete, Refresh, Docked, and Hide.
TIP: Select the Hide option to hide the Workspace explorer pane or select the Close (X) icon to close this pane.
- Select the Open option.
The workspace dashboard opens the selected workspace and displays its information.
