Using Siebel Tools > Using Siebel Tools > Using Workspaces in Siebel Tools > Submitting Workspaces for DeliveryAfter you perform the checkpoint process on the latest workspace version, you can use the Submit for Delivery option under the Workspace menu to deliver the changes of your workspace to the MAIN workspace. The Submit for Delivery process initiates the governance flow that may require one or more levels of review and approval. After the changes are submitted for delivery, the workspace is locked or read-only to prevent further configuration changes while the workspace is being reviewed. After the workspace is approved, it is delivered into the MAIN workspace. NOTE: When you select the Submit for Delivery option, the system identifies whether the rebase process is required with the current modifications. If the merge process is non-trivial, then an error message appears reminding you to run the rebase process before the system converts the workspace to read-only mode. When there is a trivial merge, the system changes the workspace status to Submitted for Delivery and converts the workspace to read-only mode. To submit a workspace for delivery
| Using Siebel Tools | Copyright © 2016, Oracle and/or its affiliates. All rights reserved. Legal Notices. | |
