This alarm indicates that the default network route is either not configured or the current configuration contains an invalid IP address or hostname.
When changing the server’s network routing configuration it is important to verify that the modifications will not impact the method of connectivity for the current login session. It is also crucial that this information not be entered incorrectly or set to improper values. Incorrectly modifying the server’s routing configuration may result in total loss of remote network access.
Recovery
