10 Oracle Utilities Data Model Data Mining Model
This chapter provides reference information about the data mining models provided with Oracle Utilities Data Model.
This chapter includes the following sections:
About Data Mining in Oracle Utilities Data Model
Oracle Utilities Data Model data mining includes data mining intra-ETL package, data mining core package, source data views, apply data views, target tables, support tables, and setting tables. The source views are defined on source derived tables. These source views are used to train the models. The target tables contain the mining model rules and mining prediction results. Data mining core package builds mining models using data in source views as training data, and applies mining models on the data in apply views. Mining target tables are populated with mining model rules and prediction results. The data in the target tables can be presented in reports.
As shown in Table 10-1, the Oracle Utilities Data Model mining models use the specified algorithms for the specific mining problem.
Table 10-1 Oracle Utilities Data Model Algorithm Used
Model Algorithms Used by Data Mining Model
Model 1: Customer Savings and Customer Profile by DR Program
Decision Tree (DT), Support Vector Machine (SVM)
Understanding the Mining Architecture
Figure 10-1 shows the architecture of data mining in Oracle Utilities Data Model. Oracle Utilities Data Model schema, oudm_sys, includes the following:
  • Mining Model Source Views: Views defined on source derived table, DWD_CUST_DR_PROG_PROFILE. These views are used to train mining models.
  • Mining Model Apply Views: Views defined on source derived tables, DWD_CUST_DR_PROG_PROFILE. These views are used to apply trained mining models.
  • Mining Model Support Tables: Mining algorithm settings for different algorithms used in Oracle Utilities Data Model are stored in the support tables. These support tables start with "DM". Building a mining model creates few tables and views which start with "DM$".
Do not delete tables and views that start with "DM" and "DM$". Deleting "DM$" tables and views would also delete the trained mining model.
  • Mining Model Target Tables: Mining model target tables used for storing mining model rules and prediction results. Mining model rules are generated from the trained model and predictions results are produced when a trained model is applied on apply data.
  • Mining Model Core Package: This is the core package for Oracle Utilities Data Model data mining. Each mining model has separate procedure in this package. Each procedure builds, tests, and applied mining model. It uses source views as training data, and applies trained model on apply views.
Figure 10-1 Oracle utilities Data Model Mining Packages Tables and Views
Description of Figure 10-1 follows
Description of "Figure 10-1 Oracle utilities Data Model Mining Packages Tables and Views"
Oracle Utilities Data Model Mining Result Tables
Table 10-2 shows the DWR_CUST_SGMNT table.
Table 10-2 DWR_CUST_SGMNT Data Mining Model Details Table
Name Data Type Description
DEMAND_RESPN_PROG_KEY
NUMBER(30)
Surrogate key of demand response program
CUST_SGMNT_KEY
NUMBER (30,0)
Surrogate key for customer segment
CUST_SGMNT_CD
VARCHAR2 (120)
Natural key for customer segment
CUST_SGMNT_MDL_KEY
NUMBER (30,0)
Customer segment model key
PRNT_CUST_SGMNT_KEY
NUMBER (30,0)
Parent segment key
CUST_SGMNT_NAME
VARCHAR2 (400)
Customer segment name
SGMNT_CRTRA_KEY
NUMBER (30,0)
Segment criteria key
CUST_SGMNT_DSCR
VARCHAR2 (1000)
Customer segment description
IS_LEAF_IND
CHAR (1)
Indicates whether the node is a leaf indicator. The prediction of lead node is the final prediction
TREE_LVL
NUMBER (4,0)
Tree level
SGMNT_DISPRSN
VARCHAR2 (500)
Segment dispersion, which is also known as intra cluster distance
SPPRTG_REC_CNT
NUMBER (16,0)
Supporting record count - number of customers in the segment
STAT_CD
VARCHAR2 (120)
Status code of the record
EFF_FROM_DT
DATE
Effective from date
EFF_TO_DT
DATE
Effective to date
Table 10-2 shows the DWR_CUST_SGMNT_DTL table.
Table 10-3 DWR_CUST_SGMNT_DTL Data Mining Model Details Table
NUMBER(30)
SGMNT_ID
NUMBER
Customer segment Identifier
ATTRIBUTE_NAME
VARCHAR2(4000)
Name of customer attribute
MEAN
NUMBER
Mean of the customer attribute if the attribute is numeric
MODE_VALUE
VARCHAR2(4000)
Model of the customer attribute if the attribute is categorical
Customers can reduce their usage by participating in a Demand Response (DR) program. The utility company needs to let customers know the savings the customer can obtain by participating in the demand response program. For this purpose, there is the need to segment whole customer population in two steps.
For each segment in STEP1, determine the average actual usage of customers not participating in DR program during the time of DR program instance; let us call it Average actual usage of non participants. In the same segment, for each participant customer determine delta (Average actual usage of non participants - customer actual usage) as a percentage of Average actual usage of non participants during the time of DR program instance.
%saving = 100*(Average actual usage of non participants - customer actual usage)/Average actual usage of non participants
"%saving" measure gives the energy saved by customer during the time of DR program instance due to participation.
STEP1: Segmentation Using Oracle Data Mining Clustering Algorithm
In this segmentation, the complete customer population is segmented into a predefined number of segments using customers' demographic attributes. By default, Oracle Data Mining chooses K-Means algorithm as the clustering function and 10 as number of segments. The default settings can be overridden using a setting a table.
Table 10-4 shows the structure of source table, which is used as training data.
Table 10-4 DWD_CUST_DR_PROG_PROFILE
Attribute Name Description Column Name Source Table Mapping
Customer Key
Customer Identifier
CUST_KEY
DWR_CUST
CUST_KEY
Demand Response Program Key
DR program Identifier
DEMOGRAPHIC ATTRIBUTES
Customer Kind
Kind of Customer
CUST_KIND_CD
DWR_CUST
CUST_KIND_CD
Customer Type
Type of customer. For example: Industrial, Commercial, Residential
CUST_TYP_CD
DWR_CUST
CUST_TYP_CD
Dwelling Type
Facility Type
DWLNG_TYP
DWR_CUST
DWLNG_TYP
Dwelling Status
Facility Status
DWLNG_STAT
DWR_CUST
DWLNG_STAT
Dwelling Size
Facility Size
DWLNG_SZ
DWR_CUST
DWLNG_SZ
Dwelling Tenure
Facility Tenure
DWLNG_TENR
DWR_CUST
DWLNG_TENR
Income Group
Income Group
INCM_GRP
DWR_HH
INCM_GRP
Number of Children
Number of children in the household
NBR_OF_CHLDRN
DWR_HH
NBR_OF_CHLDRN
Number of Teens
Number of teens in the household
NBR_OF_TEENS
DWR_HH
NBR_OF_TEENS
Number of Adults
Number of adults in the household
NBR_OF_ADLTS
DWR_HH
NBR_OF_ADLTS
Number of Seniors
Number of seniors in the household
NBR_OF_SNRS
DWR_HH
NBR_OF_SNRS
Number of Persons
Number of persons in the household
NBR_OF_PRSN
DWR_HH
NBR_OF_PRSN
Number of Earners
Number of earners in the household
NBR_OF_ERNR
DWR_HH
NBR_OF_ERNR
Business Legal Status
The legal status of the company. For example: Public, Private, and so on.
BSNS_LEGAL_STAT_CD
DWR_CUST
BSNS_LEGAL_STAT_CD
Customer Revenue Band
CUST_RVN_BND_CD
DWR_CUST
CUST_RVN_BND_CD (Derive it from payment and cost)
Nationality
Nationality
NTNLTY_CD
DWR_CUST
NTNLTY_CD
Education
Education Qualification
EDU_CD
DWR_CUST
EDU_CD
Marital Status
Marital Status
MRTL_STAT_CD
DWR_CUST
MRTL_STAT_CD
Gender
Gender
GNDR_CD
DWR_CUST
GNDR_CD
Job Position
Job Position
JB_POSN
DWR_CUST
JB_POSN
Annual Revenue
Annual Revenue
ANNUAL_RVN
DWR_CUST
ANNUAL_RVN (o for residential customers)
Annual Sales
Annual Sales
ANNUAL_SL
DWR_CUST
ANNUAL_SL (o for residential customers)
Equity Amount
Equity Amount
EQTY_AMT
DWR_CUST
EQTY_AMT (o for residential customers)
City
City
CITY
DWR_CUST
CITY
State
State
STATE
DWR_CUST
STATE
Country
Country
COUNTRY
DWR_CUST
COUNTRY
Ethnic Background
Ethnic Background
ETHNIC_BCKGRND
DWR_CUST
ETHNIC_BCKGRND
Source of Income
Source of Income
SRC_OF_INCM
DWR_CUST
SRC_OF_INCM
Special Need
Special Need
SPL_NEED
DWR_CUST
SPL_NEED
Economically Active Indicator
ECNMCLY_ACTV_IND
DWR_CUST
ECNMCLY_ACTV_IND
Domestic Indicator
Domestic company Indicator
DMSTC_IND
DWR_CUST
DMSTC_IND
Mail Allowed Indicator
MAIL_ALWD_IND
DWR_CUST
MAIL_ALWD_IND
Third Party Marketing Allowed Indicator
THIRD_PRTY_MKTG_ALWD_IND
DWR_CUST
Customer Payment Responsible Indicator
CUST_PYMT_RESPBL_IND
DWR_CUST
VIP
VIP Flag
VIP
DWR_CUST
VIP
TARGET/OUTPUT ATTRIBUTES
Customer Segment Code
CUST_SGMNT_CD
TECHNICAL QUALITY
Creation Date
Date when this record is created
CREATED_DT
SYSDATE
Created By
User who created this record
CREATED_BY
USER
Updated Date
Date when this record updated
UPDATE_DT
SYSDATE
Updated By
User who updated this record
UPDATE_BY
USER
Effective from Date
Date from when this record is effective
EFF_FROM_DT
SYSDATE
Effective to Date
Date until when the record is effective
EFF_TO_DT
NULL
Current Indicator
Whether this record is current or not. 'Y' - Yes, 'N' - No
CURR_IND
'Y'
Status Code
Status of this record. 'A' - Active, 'I' - Inactive
STAT_CD
'A'
Algorithms Used
Following algorithm is used to segment customers:
  • K-Means
Algorithm Setting Table
DM_STNG_CUST_PROFILE is the setting table used for STEP1 segmentation using Oracle Data Mining segmentation algorithm. Following table shows the different settings used:
Table 10-5 shows setting values for STEP1 segmentation.
Table 10-5 Setting Values for STEP1 Segmentation
SETTING_NAME SETTING_VALUE
DBMS_DATA_MINING.ALGO_NAME
ALGO_KMEANS
DBMS_DATA_MINING.KMNS_DISTANCE
KMNS_EUCLIDEAN
DBMS_DATA_MINING.KMNS_ITERATIONS
4
DBMS_DATA_MINING.CLUS_NUM_CLUSTERS
5
STEP2 Segmentation and Customer Saving Calculation
As mentioned earlier, each STEP1 segment can have both DR program participant customers and non-participant customers. Each STEP1 segment is further segmented into two segments using customer participation indicator; that is, one sub-segment for participant customers and the other sub-segment for non-participant customers.
For each STEP1 segment:
  • Calculate the average of actual usage of non-participant customers during the DR program, let us call it Average actual usage of non participants
  • For each participant customer, compute %saving as follows:
%saving =
Description of dm_calc1.png follows
For each participant customer, PERCNT_CUST_SAVNG column in mining target table DWD_CUST_DR_PROG_PROFILE is updated with the calculated %saving.
Oracle Utilities Data Model Mining Setting Tables
Use the algorithm settings tables to override default values of different settings of mining algorithms.
The following two setting tables have the same structure:
  • DM_STNG_USER_ALL
  • DM_STNG_PROFILE_KMEANS
Table 10-6 shows the structure of the two setting tables.
Table 10-6 Data Mining Setting Table
SETTING_NAME
VARCHAR2(500)
Setting Name
SETTING_VALUE
VARCHAR2(500)
Setting Value
