Use this procedure to generate and view a measurements report.
Click Measurements > Report.
Select the Scope.
For details about this field, or any field on the Measurements > Report page, see Measurement elements.
Select the Report.
Click Interval.
Click Time Range.
Select Beginning or Ending as the Time Range interval reference point.
Select the Beginning or Ending date.
Click Go.
Note: Data for the selected scope is displayed in the primary report page. Data for any available sub-scopes are displayed in tabs. For example, if the selected scope is Entire Network, report data for the entire network appears in the primary report page. The individual network entities within the entire network are considered sub-scopes.
To view report data for a specific sub-scope, click on the tab for that sub-scope.
