Generating a SFTP User report
A SFTP user report can be generated. Use this procedure to generate a SFTP user report.
Click
Administration
Access Control
SFTP
Click
Report
It is unnecessary to select a particular user, because all users appear in the Users Report.
The SFTP Users report is generated. This report can be printed or saved to a file.
Click
Print
to print the report.
Click
Save
to save the report to a file.
Parent topic:
SFTP Users Administration
