11. Scenario Analysis
11.1 Introduction
With the Scenario Analysis screen, you can simulate the customer’s Line of credit request Line of credit amount, rate and create a mock proposal in Line of credit with your lending policies.
You can use scenario analysis screen to complete the following tasks:
Note
Depending on the product licensed, you can view either Loan or Lease Calculator details. If you have licensed both, then you are provided with an option in Scenario Analysis screen to select the required Product Type.
11.1.1 View an Existing Scenario Analysis
You can view a previously generated scenario analysis by inquiring through the identification code,
To view an existing scenario analysis
  1. Click Origination > Origination > Scenario Analysis. The Scenario Analysis screen is displayed in the main window.
  2. Either specify the identification code of a previously generated scenario analysis in the Inquiry Id field, or select the identification code from the adjacent drop-down list.
  3. Click Show Details.
11.1.2 Generating Scenario Analysis
To generate a scenario analysis
Click Add and complete the following Parameters:
You can click Initialize to clear (or ‘refresh’) the screen details at any time.
Field
Do this:
Inquiry Id
View the inquiry identification code.
Application #
View the application number.
First Name
Specify the first name of the applicant.
Last Name
Specify the last name of the applicant.
Phone
Specify the phone number of the applicant.
Email
Specify the email address of the applicant.
Company
Select the company.
Branch
Select the branch.
Product
Select the product.
Producer Type
Select the producer type associated with the product.
Producer Name
Select the producer associated with the product.
Producer Contact Number
View the producer contact number.
Region
View the region where the producer belongs.
Territory
View the territory where the producer belongs.
Term
Specify the requested term (number of payments).
State
Select the state code.
Asset Type
Select the asset type.
Asset Sub type
Select the asset sub type.
Make
Specify the make of the vehicle.
Model
Specify the model of the vehicle.
Promotion
Select the requested promotion.
Billing Cycle
Select the billing cycle schedule.
Instrument
Select the instrument.
  1. In the Calculator section, you can specify the details of various Parameters.
    For detailed field information, refer to Calculator section in Tools Chapter.
  2. After you have specified all the required details, Click Save And Stay or any other required save option. For more details on save options, refer to ‘Basic Actions’ section in Navigation chapter.
The system auto assigns an identification code to your calculations on the Scenario Analysis screen.
11.1.3 Auto Suggest Pricing for the Scenario Analysis
The Scenario Analysis screen provides an option to calculate and display the Pricing based on previously generated scenario analysis details.
  1. In the Scenario Analysis section, specify the required information to generate scenario analysis and save the details. (Refer section Generating Scenario Analysis).
  2. click Suggest. The system displays the Pricing details.
11.1.4 Creating an Application from the Scenario Analysis
To create an application from the scenario analysis
  1. Specify the required information to generate scenario analysis. (Refer section Generating Scenario Analysis)
  2. Click Create App.
11.1.5 Generating a quote from the scenario analysis
You can generate a summarised report using the calculated details in the format of quote.
After you have specified all the required information to generate scenario analysis, (Refer section Generating Scenario Analysis), click Print Quote.
For detailed information, refer to Printing a Quote section in Tools chapter.
11.2 Viewing Information from Scenario Analysis
The system assigns the information on the Scenario Analysis screen an application number. You can open this application on the Application Entry screen and view information from the Scenario Analysis screen at the following locations:
In the Underwriting screen, the Decision link’s Pricing and Approved sections display the details from the Scenario Analysis screen. You can modify the price chosen in the Scenario Analysis screen and re-price the application. If application has been repriced, the comments regarding the multiple offers on the Comment screen should be manually updated before approving the application.
