7. Configure AQ-JMS Bridge
The following steps are to be performed to configure the AQ-JMS Bridge
through the Weblogic Console:
Note
Ensure that MDB EJB is not configured and deployed
(i.e. OfsllQueueApp.ear deployment) on the same server on which
the other WebServices are deployed.
7.1 Create Data Sources for AQ-JMS Bridge
- Login to Oracle Weblogic 12c console (http://hostname:port/console).
- On
successful login, the following window is displayed.
- Click
Domain Name > Services > Data Sources. The following window is
displayed.
- Click
‘Lock & Edit’ button on the left panel. Click ‘New’
on right panel and select ‘Generic Data Source’.
- The
- Specify the following
details:
- Enter Data source Name
- Enter the JNDI Name as ‘jdbc/aqjmsdb’.
Note
If required, you can specify any other JNDI name,
but however ensure to use the same JNDI name during other configuration
steps.
- Select ‘Oracle’ as Database Type.
- Click ‘Next’. The following window is displayed.
- Select the Database
Driver ‘Oracle's Driver(Thin XA) for Services connections;Versions:Any’.
- Click ‘Next’.
- Enter the Database
details.
- Click ‘Test
Configuration’. On completion, displays a confirmation message
as ‘Connection test succeeded’.
- Select target Server
as ‘OFSLLREL_ManagedServer’.
- Click ‘Finish’ to activate the changes.
7.2 Configure MDB Flow
To configure the MDB Flow from Weblogic Console, do the following:
- On the left pane, click 'Services'.
- In Messaging tree click ‘JMS Modules’. The
- Click 'New'. The following
screen is displayed.
details:
- Name: AQJMSModule
- Descriptor File Name: AQJMSModule
- Select target servers
- Click ‘Finish’
to activate the changes. The following window is displayed.
- Click on the JMS
Module that you created. The following window is displayed.
- Click ‘New’
in ‘Summary of Resources’ section. The following window is
displayed.
- Select ‘Foreign
Server’ as the option for type of resource to be created.
- Click ‘Finish’
and activate the changes. The following window is displayed.
- Click on the Foreign
Server that you created. The following window is displayed.
details:
- Enter JNDI Initial Context Factory as ‘oracle.jms.AQjmsInitialContextFactory’.
- JNDI Properties as ‘datasource=jdbc/aqjmsdb’.
- Ensure ‘Default Targetting Enabled’ option is selected.
- Click ‘Save’.
- Select ‘Destinations’ Tab and click ‘New’
to create new destination. The following window is displayed.
details:
- Name: AQJMSQueue
- LocalJNDI Name: /jms/aq/OfsllQueue
- Remote JNDI Name: Queues/OFSLL_OUTBOUND_Q
- Click ‘OK’ and save the changes.
- Select ‘Connection Factories’ Tab and click
‘New’ to add new connection factory. The following window
is displayed.
details:
- Name: AQofsllCF
- Local JNDI Name: /jms/aq/OfsllCF
- Remote JNDI Name: XAQueueConnectionFactory
7.3 Create Credentials and System Policies
In order Configure MDB flow, you need to create credentials and system
policies. The credentials are accessed through CSF framework which is
managed by Oracle Weblogic Server. The keys are managed by Maps and Maps
need to be given with Permissions.
- Login to Oracle Enterprise Manager (http://hostname:port/em).
- On the left panel, right click on OFSLL_domain and select
Security > System Policies > Credentials. The following window
is displayed.
- Click ‘Create
Map’. The following window is displayed.
- Enter Map Name as
‘ofsll.int.bureau’ and click ‘OK’.
- Click ‘Create Key’. The following window is
displayed.
details:
- Select Map as ‘ofsll.int.bureau’ from the drop down list.
- Specify Key as ‘jdbc_ds_key’
- Select Type as ‘Generic’ from the drop down list.
- Specify the Credential as ‘jdbc/aqjmsdb’
- Click ‘OK’.
- Similarly you need to create the following Maps and corresponding
keys as indicated in following table.
Maps
Keys
Description
ofsll.int.bureau
This map is used to setup
keys for all credit bureau interfaces
ProxyServer
Name of the proxyServer
to be configured
ProxyPort
Port to which ProxyServer
is running.
ExpEcalsURL
The Experian Connection
URL to be configured.
ExpDirectExperianEnabled
If you set value as true,
then you would be setting ecals response URL. Else, the Ecals request
URL
ExpCertPath
The location of .jks file
which contains the valid certificate for Experian Credit Bureau.
ExpBusUserNamePassword
Login Credentials to be
configured for Experian Business reports.
ExpConUserNamePassword
configured for Experian Consumer reports.
EfxURL
The Equifax Connection
EfxCertPath
which contains the valid certificate for Equifax Credit Bureau.
EfxUserNamePassword
Login credentials to be
configured for accessing Equifax Reports.
TucCertPath
The location of .p12 file
which contains valid certificate for Transunion Bureau .
TucCertPassword
The password that requires
to read the valid .p12 certificate for the Transunion Bureau.
TucUserNamePassword
configured for accessing Transunion reports
TucConnectionURL
The Transunion URL to be
configured.
ofsll.int.outbound
keys for the RouteOne and Dealer track call back from OFSLL.
roUserNamePassword
Login Credentials used
at the time of call back from OFSLL to RouteOne Interface.
dtUsernamePassword
at the time of Call back from OFSLL to Dealer Track Interface.
ofsll.int.bip
This Map is used to setup
all the Keys required to setup interface with BIP to generate reports.
local_top_dir
Define the path of the
local BIP server where you would like place the generated BIP reports.
email_from_addr
Define the From Email address
to be used while sending email for the generated BIP reports.
emailBodyContentPath
The path for ‘file.properties’
file that contains the content of the subject and body required while
sending letter, report or correspondence as mail to the applicant or
producer.
For example; /tmp/file.properties
*Refer to note below for details on ‘file.properties’
file creation for email configuration.
fax_server
Configure the name of Fax
server to be used to fax the generated BIP reports.
ofsll.int.filetransfer
sftp_key
Credentials to login to
SFTP server(Username/Password)
sftp_top_dir
Top root directory for
SFFTP server
sftp_servers
SFTP server names
ofsll.int.security
bip_key
This is BIP login credentials
* A new file(file.properties) needs to be created and copied to the
application server in the same path as mentioned in the value corresponding
to the key 'emailBodyContentPath' under the map 'ofsll.int.bip'. The
file should have the following contents:
- letter_subject='Text that is configurable and would be the subject
of the mail'
- letter_body='Text that is configurable and would be the body of the
mail'
- correspondence_subject='Text that is configurable and would be the
subject of the mail'
- correspondence_body='Text that is configurable and would be the body
of the mail'
- report_subject='Text that is configurable and would be the subject
of the mail'
- report_body='Text that is configurable and would be the body of the
mail'
Security > System Policies. The following window is displayed.
- Click ‘Create’.
- Enter the codebase
as ‘file:${domain.home}/lib/OfsllCommonCSF.jar’
- Click ‘Add’. The following window is displayed.
- Select the check
box 'Select here to enter details for a new permission'.
- Specify the following details as the first permission
class.
Permission Class
Resource Name
Permission Actions
oracle.security.jps.service.credstore.CredentialAccessPermission
context=SYSTEM,mapName= ofsll.int.bureau,keyName=*
read
context=SYSTEM,mapName= ofsll.int.filetransfer,keyName=*
read
context=SYSTEM,mapName= ofsll.int.outbound,keyName=*
read
context=SYSTEM,mapName= ofsll.int.bip,keyName=*
read
context=SYSTEM,mapName=ofsll.http.listener.jndi,keyName=*
read
- Click ‘OK’.
7.4 Deploy MDB EJB
- Login to Web Logic application server enterprise manager
(e.g.:http://hostname:port/em)
- Enter valid login credentials. The following window is displayed.
- Click ‘Deployment’ in the left panel.
- Select ‘Lock & Edit’ option in the lock
drop-down list available in the header. The following window is displayed.
- Select ‘Deploy’ from the Deployment drop-down list.
- The following window is displayed.
- Browse to the
folder containing the MDB EJB. Eg: C:/OfsllQueueApp.ear
- Select the
server on which the MDB EJB needs to be deployed.
- Select the
option ‘Install and start application (servicing all requests)’.
- Check the context root and click ‘Next’.The
- Click ‘Deploy’.
On successful deployment, the following window is displayed.
- Click ‘Close’.
Post deployment, you need to activate the changes by selecting ‘Active
Changes’ option from ‘Edit Session’ drop-down list
as indicated in step 4 above.
Note
While starting the ‘OFSLLREL_ManagedServer’,
always start with option ‘-DUseSunHttpHandler=true’
to enforce the weblogic server to uses SUN SSL implementation.
