Go to primary content
Oracle® Retail Merchandising Cloud Suite Customization and Extension Guide
Release 22.1.301.0
F59750-01
  Go To Table Of Contents
Contents
Previous
Previous
Next
Next
5 Merchandising Style Guide
This section outlines the styles used in developing the Merchandising solution user interfaces. It is included here so that you can use the information for any custom reports or bolt-on applications to give them a similar look and feel, providing a more seamless experience for your users.
Fonts
The primary typeface that is used for the UI is Arial, with Helvetica used for some of the headings.
Fonts Styles
Colors
These are the colors used in the UIs. Which colors apply for which components is described below.
User Interface Example Colors
Global Screen Structure
All the screens in Merchandising have a similar layout, with these main key areas:
  1. Global Navigation Bar
  2. Application Tabs
  3. Navigational Area
  4. Local Area
  5. Contextual Area
The global navigation bar shows the name of the solution and also contains the user menu and a global help icon. The makeup of this bar is as follows:
Components Font Background Color Size
Top Border
Red Height: 2 pixels
Main Section Application title: Headline 1 Light Gray Height: 42 pixels
Bottom Border
Medium Gray Height: 1 pixel
Application Menu Bar
Menu Button section N/A Light Gray Width: 40 pixels
Fly-out Menu Body Text Light Gray Width: 250 pixels
Application Tabs
Application Tabs
Active tab Standard Link State, Bold White
Border: Blue
Height: 30 pixels (border 3 pixels)
Width: minimum 80 pixels
Inactive tab Standard Link State White Height: 30 pixels (no border)
