Go to primary content
Tekelec Platform Operations, Administration, and Maintenance (OAM)
Release 7.5
E88997
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Inserting an Interface DSCP
Use the following procedure for inserting an interface DSCP.
  1. Click Configuration > DSCP > Interface DSCP.
  2. Remain on the tab for Entire Network or select a server group tab.
  3. Select a server sub-tab for the interface, or alternatively if a server group tab is selected and the interface is for all servers in the server group select the Entire Server Group sub-tab
  4. Click Insert.
  5. Select the Interface from the list of available server interfaces.
  6. Enter a valid DSCP value. A valid value is an integer between 0 and 63, inclusive.
  7. Select TCP or SCTP protocol from the list.
  8. Click OK to submit the information and return to the DSCP page, or click Apply to submit the information and continue entering additional data.
The new DSCP is added.
