Caution:
When changing the network routing configuration of the server, verify that the modifications will not impact the method of connectivity for the current login session. The route information must be entered correctly and set to the correct values. Incorrectly modifying the routing configuration of the server may result in total loss of remote network access.Recovery:
The default router at <IP_address> cannot
be pinged, the router may be down or unreachable. Do the following:
The default route is not on the provisioning
network, it is recommended to collect the syscheck output and contact
unresolvable-reference.htm#GUID-DD0927BD-FD0B-4CEB-86E9-98A33C12D4E0.
An active route cannot be found for a
configured default route, it is recommended to collect the syscheck
output and contact
