19422 - BDFInvalidPkt
			 - Alarm Group
			 - SMS
			 - Description
			 -  The BDF subsystem received a StackEvent that was
				somehow invalid, corrupt, or could not be delivered to the application.
			 - Severity
			 -  Info
			 - Instance
			 - <Source IP>
			 - HA Score
			 - Normal
			 - Throttle Seconds
			 - 0 (zero)
			 - OID
			 - cAFBroadcastDataFrameworkInvalidStackEventNotify
	 Recovery:
		  If more messages of the same type occur, then check
			 the site(s) and network for other possible corruption or overloaded conditions.
			 It is recommended to contact
			 unresolvable-reference.htm#GUID-DD0927BD-FD0B-4CEB-86E9-98A33C12D4E0 for
			 assistance if needed.
