Go to primary content
User Data Repository Alarms, KPIs, and Measurements
Release 12.4
E82598-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
RxRoutedPrt
Measurement ID
10060
Measurement Group
Routing Usage
Measurement Type
Simple
Measurement Dimension
Arrayed (by Connection ID)
Description
The number of Request messages routed using Peer Routing Rules.
Collection Interval
5 min
Peg Condition
When the DSR selects the highest priority Peer Routing Rule which matches message content. The connection measurement is associated with the connection from which the Request message was received.
Measurement Scope
Server Group
Recovery
  1. No action required.
