10078 - Application not restarted on standby server due to disabled failure cleanup mode
- Event Type:
- HA
- Description:
- The Applications on the Standby server have not been restarted after an active-to-standby transition since h_FailureCleanupMode is set to 0.
- Severity:
- Info
- Instance:
- N/A
- HA Score:
- Normal
- Throttle Seconds:
- 1
- OID:
- failureRecoveryWithoutAppRestartNotify
Recovery:
- It is recommended to contact My Oracle Support.
