Go to primary content
User Data Repository Alarms, KPIs, and Measurements
Release 12.4
E82598-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
EvMpCongestionLevel3Entered
Measurement ID
10289
Measurement Group
MP Performance
Measurement Type
Simple
Measurement Dimension
Single
Description
The number of times that the local DA-MP entered CPU congestion level 3.
Collection Interval
5 min
Peg Condition
Each time Alarm 22200 - Local MP Congestion (refer to the DSR Alarms and KPIs Reference for details about this alarm) transitions from "cleared" or asserted with severity "Info", "Minor", or "Major" to asserted with severity "Critical".
Measurement Scope
Server Group
Recovery
  1. If one or more MPs in a server site have failed, the traffic will be distributed amongst the remaining MPs in the server site. DA-MP server status can be monitored from Main Menu > Status & Manage > Server Status.
  2. The misconfiguration of Diameter peers may result in too much traffic being distributed to the MP. The ingress traffic rate of each DA-MP can be monitored from Main Menu > Status & Manage > KPIs. Each DA-MP in the server site should be receiving approximately the same ingress transaction per second.
  3. There may be an insufficient number of MPs configured to handle the network traffic load. The ingress traffic rate of each DA-MP can be monitored from Main Menu > Status & Manage > KPIs. If all MPs are in a congestion state, then the offered load to the server site is exceeding its capacity.
  4. The Diameter Process may be experiencing problems. The alarm log be examined from Main Menu > Status & Manage > Alarms & Events.
  5. If the problem persists, it is recommended to contact My Oracle Support.
