The KPI values associated with MP are available using .
Table 4-5 MP KPIs
| Variable | Description |
| Avg CPU Utilization | Percentage of CPU utilization by the Diameter process on a DA-MP server. |
| Offered Load (MPS) | Offered load on a DA-MP server, corresponding to the message rate before policing by capacity and congestion controls. |
| Accepted Load (MPS) | Accepted load on a DA-MP server, corresponding to the message rate after policing by capacity and congestion controls. |
| Messsage Processing Load (MPS) | Average message processing load (messages per second) on a MP server. The message processing load is the number of Diameter messages that are routed, including Reroute and MsgCopy. |
