RxRoutedPeerDirect
- Measurement ID
- 10061
- Measurement Group
- Routing Usage
- Measurement Type
- Simple
- Measurement Dimension
- Arrayed (by Connection ID)
- Description
- The number of Request messages implicitly routed directly to a peer.
- Collection Interval
- 5 min
- Peg Condition
- When the DSR does not find a Peer Routing Rule that matches message content, the Destination-Host AVP is present and its value matches a FQDN of a peer, and the peer is available for egress routing. The connection measurement is associated with the connection from which the Request message was received.
- Measurement Scope
- Server Group
Recovery
- No action required.
