22009 - Application Routing Rules with Same
	 Priority
			 - Event Type:
			 - DIAM
			 - Description:
			 - An application routing table search with a received
				Request message found more than one highest priority application routing rule
				match. At least two application routing rules with the same priority matched an
				ingress Request message. The system selected the first application routing rule
				found.
			 - Severity:
			 - Info
			 - Instance:
			 - <MPName>
			 - HA Score:
			 - Normal
			 - Throttle Seconds:
			 - 10
			 - OID:
			 - eagleXgDiameterApplicationRoutingTableRulesSamePriorityNotify
	 Recovery:
		  It is recommended that application routing rules be
			 unique for the same type of messages to avoid unexpected routing results. Peer
			 routing rule priorities can be modified using
			 Diameter > Configuration > Application
				Route Tables page.
		  If the problem persists, it is recommended to
			 contact
			 unresolvable-reference.htm#GUID-DD0927BD-FD0B-4CEB-86E9-98A33C12D4E0.
