Use this task to edit a Local Node.
When the page opens, the fields are initially populated with the current values for the selected Local Node.
Configuration considerations:
- The Local Node Name cannot be changed.
- The following fields cannot be edited if there is at least one associated Enabled connection:
- Realm
- FQDN
- SCTP Listen Port (and the Transport Protocol is SCTP)
- TCP Listen Port (and the Transport Protocol is TCP)
- DTLS/SCTP Listen Port
- TLS/TCP Listen Port
- RADIUS UDP Server Ports
- RADIUS UDP Client Ports
- Enable RADIUS UDP Port Range Start
- Enable RADIUS UDP Port Range End
- Verification Mode
- Certificate Type
- Certificate Name
- Connection Configuration Set
- CEX Configuration Set
- IP Address (cannot be removed if there is an Enabled connection, but a new IP Address can be added)
