Go to primary content
User Data Repository Diameter User's Guide
Release 12.4
E92984-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Diameter Maintenance Peer Nodes
The Diameter > Maintenance > Peer Nodes page provides the operational status of Peer Node connections, including a reason for the status.
You can perform these tasks on an Active System OAM (SOAM).
On the Diameter > Maintenance > Peer Nodes page, you can perform the following actions:
  • Filter the list of Peer Nodes to display only the desired Peer Nodes.
  • Sort the list by a column, in ascending or descending order, by clicking the column heading (except MP Server Hostname and Connection). The default order is by Peer Node Name in ascending ASCII order.
  • Click the + in any entry in the Connection field to view information about the Connections associated with the Peer Node.
  • With an entry in the Connection field expanded, click the Connection Name to go to the maintenance page for the Connection.
  • Prevent the page from automatically refreshing by clicking the Pause updates check box.
