If OK or Apply is clicked and any of the following conditions exist, then an error message appears:
If you attempt to edit a Route List instance whose Dynamic attribute is YES, a warning message displays, but the edit operation is allowed to proceed. Editing a dynamic route is allowed, but changes are lost to this Route List if the Realm to which the Route List is associated is dynamically re-discovered in the future.
If you attempt to delete a Route List instance whose Dynamic attribute is YES.
If you attempt to insert or edit a static Route List, one or more of the Route Groups supplied in the desired configuration has for its own Dynamic attribute a value of YES.
If youattempt to change one or more read-only attributes.
When editing a Route List instance whose Dynamic attribute is YES, all Route List attributes are treated as read-only except for Route Across Route Groups.
If you attempt to edit a static Route List instance by changing its Dynamic attribute from NO to YES or vice-versa.
If youattempt to add a Route List instance and the Dynamic attribute is YES. A Route List instanceDynamic attribute must be YES to be inserted using Dynamic Peer Discovery.
Any required field is empty; no value was entered or selected
The entry in any field in not valid (wrong data type or out of the valid range)
The selected Route List no longer exists (has been deleted by another user)
A selected Route Group no longer exists (has been deleted by another user)
A selected Route Group is a duplicate within the Route List
A Route Group Priority is not unique within the Route List
