Go to primary content
User Data Repository Diameter User's Guide
Release 12.4
E92984-01
Go To Table Of Contents
Contents
Previous
Previous
Next
Next
Adding Peer Node Groups
Use this task to create new Peer Node Groups.
  1. Click Diameter > Configuration > Peer Node Groups.
  2. Click Insert.
  3. Enter a unique name for the Peer Node Group Name in the Peer Node Group Name field.
  4. Select a Peer Node Name from the Peer Node Name list.
    To add another Peer Node Name, click Add and select a Peer Node Name in the new text box.
  5. Click OK, Apply, or Cancel.
    The following conditions exist:
    • You can only specify Peer Nodes whose Dynamic attribute is NO to be selected for inclusion in a Peer Node Group.
    • Peer Nodes created by the Dynamic Peer Discovery feature cannot be included by any Peer Node Group instance.
    • If you attempt to insert or update a Peer Node Group instance and the specified Peer Node whose Dynamic attribute value is YES.
    • Peer Route Groups are always statically configured; no statically configured instance can refer to a dependent GUI element that was added to the configuration as a result of Dynamic Peer Discovery.
