Use
this procedure to add an SNMP Manager:
Select
The SNMP Trapping page opens.
Update Enabled
Versions as appropriate.
For more information about Enabled Versions,
or any field on this page, see SNMP administration elements.
Select an empty Manager field, and populate it with the hostname
or IP address of the SNMP manager.
(Optional) Enable traps from individual servers.
(Optional) For SNMPv2c managers, change the SNMPV2c Read-Only
Community Name.
(Optional) For SNMPv2c managers, change the SNMPV2c Read-Write
Community Name.
(Optional) For SNMPv3 managers, select an SNMPv3 Security Level,
and change:
- SNMPv3 Engine ID
- SNMPv3
Authentication Type
- SNMPv3 Privacy
Type
For SNMPv3 managers with user authentication enabled, configure
SNMPv3 Username.
For SNMPv3 managers with privacy enabled, configure SNMPv3
Password.
Click
OK or
Apply to submit the information.
The new
manager and related settings are saved and activated.
