When an audit is run, two files are created: an .ixml and a .dbauditor file. The names of these files are determined by the text entered in the Result File Name field. The format of the file name is Audit_<Result File Name>_<timestamp>.
The .dbauditor file is used as input in the clean process. It stores statistics and the state for the most recent run, audit, or clean.
When a clean is run, this process also creates a log file. This filename is Clean_<Result File Name>_<timestamp>.
