1. Preface
1.1 Introduction
This manual is designed to help you quickly get acquainted with the Common Core Gateway Maintenances of Oracle FLEXCUBE.
It provides an overview to the module, and provides information on using the Common Core Gateway module of Oracle FLEXCUBE.
You can further obtain information specific to a particular field by placing the cursor on the relevant field and striking <F1> on the keyboard.
1.2 Audience
This manual is intended for the following User/User Roles:
Role
Function
IT department members responsible for integration
Input functions for maintenance related to the gateway
IT managers
Authorization functions
1.3 Documentation Accessibility
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
1.4 Organization
This manual is organized as follows:
Chapter
Description
Chapter 1
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual.
Chapter 2
Gateway Functions - An Overview explains the features of this mod­ule.
Chapter 3
Gateway Maintenances explains the core features of this module.
Chapter 3
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation.
1.5 Glossary of Icons
This User Manual may refer to all or some of the following icons.
Icons
Function
Exit
Add row
Delete row
Option List
1.6 Related Documents
For further information on procedures discussed in the manual, refer to the Oracle FLEXCUBE manuals on:
