This manual is designed to help acquaint you the generation of Single Customer View (SCV) Handoff file by Oracle FLEXCUBE, which is a regulatory requirement in UK as per Financial Services Compensation Scheme (FSCS).
This manual provides you extensive explanations about the various maintenances required for the generation of handoff file in the required format as regulated by Financial Services Compensation Scheme (FSCS).
This manual is intended for the following User/User Roles.
Role |
Function |
Back office clerk |
Input functions for contracts |
Back office managers/officers |
Authorization functions |
Product Managers |
Product definition and authorization |
End of day operators |
Processing during end of day/ beginning of day |
Financial Controller / Product Managers |
Generation of reports |
For information about Oracle's commitment to accessibility, visit the Oracle Accessibility Program website at http://www.oracle.com/pls/topic/lookup?ctx=acc&id=docacc.
This manual is organized as follows:
Chapter |
Description |
Chapter 1 |
About this Manual gives information on the intended audience. It also lists the various chapters covered in this User Manual. |
Chapter 2 |
Single Customer View Hand-off explains the process of generating Single customer view file for addressing the regulatory authority requirement. |
Chapter 3 |
Function ID Glossary has alphabetical listing of Function/Screen ID's used in the module with page references for quick navigation. |
Abbreviation |
Description |
System |
Unless and otherwise specified, it shall always refer to Oracle FLEXCUBE system |
EOD |
End Of Day |
SCV |
Single Customer View |
FSCS |
Financial Service Compensation Scheme |
DGSD |
Deposit Guarantee Schemes Directive |
This User Manual may refer to all or some of the following icons.
Icons |
Function |
Exit |
Add row |
Delete row |
Option List |
