Before you begin using the Securitization of Islamic Assets module, you need to capture Formula Definition which is used to filter or identify the finance contracts that forms part of the securitization pool.
Oracle FLEXCUBE allows you to capture rule condition, which is used to identify the finance contracts to form the securitization pool. You can maintain the formula details in the ‘Islamic Securitization Formula Maintenance’ screen. You can invoke this screen by typing ‘SZDFRMNT’ in the field at the top right corner of the Application toolbar and clicking on the adjoining arrow button.
Here you can capture the following details:
Formula Name
Specify the formula name.
Description
Specify the description for the formula.
Condition ID
Specify the condition ID.
Description
Specify the description for the condition.
Rule Condition
Specify the rule condition.
The system provides the following pre-defined elements to form the rule expression:
While creating the securitization pool, the system computes the values for the elements dynamically and executes the expression.
You should use the Rule Name and Condition Name in securitization pool addition / deletion screen to execute the specific condition.
Note
The system allows you to modify the formula. This modification will not have any impact on the already selected finance accounts in the securitization pool based on the modified formula.
You can view the summary details of the Securitization Formula Maintenance in ‘Securitization Formula Maintenance Summary’ screen’.
You can invoke this screen by typing ‘IZSFRMNT’ in the field at the top right corner of the Application tool bar and clicking on the adjoining arrow button.
In this screen, you can query based on any combination of the following fields:
After specifying the parameters for the query, click ‘Search’ button. The system displays all the records matching the parameters specified.
