The messaging preferences that you indicate for your branch will govern the workflow aspects of the messaging system module. You can specify messaging preferences for your branch in the ‘Messaging Branch Preferences’ screen. In this screen you can indicate:
Note
You can specify preferences only for the branch from which you logged onto Oracle FLEXCUBE.
This section contains the following topic:
To invoke the ‘Messaging Branch Parameters Maintenance’ screen, type ‘MSDPREF’ in the field at the top right corner of the Application tool bar and click the adjoining arrow button.
If you are maintaining preferences for a new branch of your bank, click the ‘New’ button on the Application toolbar. The ‘Messaging Branch Parameters Maintenance’ screen is displayed without any details.
If you are calling a branch preference record that has already been defined, double-click a record of your choice from the summary screen. In the ‘Summary’ screen, all the branch preference records that you have entered will be displayed in a tabular form.
The screen is shown below:
In the ‘Messaging Branch Parameters Maintenance’ screen you can only maintain (create or modify) the preferences for the current logged in branch. However, you can view the preferences maintained for other branches.
Following are the details captured here:
Branch
Specify the branch for which you are maintaining the preferences.
Message Archive Period
Archival is the process of storing old messages for future retrieval. You can specify the number of days for which an outgoing message should be kept in the Outgoing Message Browser.
A message will be automatically archived after the number of days that you specify. You can un-archive the details of outgoing message that has been archived by invoking the ‘Message History Retrieval’ screen. After you un-archive an outgoing message you can process it just as you would any other outgoing message.
Note
It is recommended that you indicate a value of ‘one’ in this field. In this case, only those messages that have been triggered for generation today will be displayed in the Outgoing Message Browser.
PDE Archive Period
Specify the number of days for which messages should be kept in the queue for PDE Possible Duplicate Emission) identification. System does not consider messages for PDE identification post the PDE archive period maintained here.
Note
The PDE archive period should be less than or equal to message archival days.
Text for Duplicate
Every message is maintained in the Outgoing Browser, as an un-generated copy of the original. When the copy is generated, it will contain, along with the contents of the original message, any additional text that you have maintained in the Text for Duplicate field.
Hold Mail Text
All the mail advices generated for a customer for whom ‘Add Hold Mail Text’ is checked at the Customer Address Maintenance would have the hold mail text maintained in this field. This text will be displayed on top of the message.
Test Word Check
You can indicate whether a testword needs to be entered before a telex message is generated from and received at your branch. You can state your preference from the Yes/No option that is available.
PDE Functional Validation
Check this box to indicate that system should identify an outgoing message as PDE (Possible Duplicate Emission) using functional key or not.
The PDE validation is done either using the hash value of the SWIFT message or using the tag/field value of the message. If this option is checked, Oracle FLEXCUBE identifies duplicate messages by performing PDE functional validations also. Hash value based validation shall be done irrespective of this option being checked.
Indicating the activities that require authorization
You can perform several activities on a message that is to be generated from your branch and on those that have come in for your branch. For example, from the outgoing or incoming browser, you can change the address to which a message should be sent.
In the branch preferences screen, you can indicate the activities which when performed on an incoming or outgoing message, would require subsequent manual authorization for the message. Several activities have been listed in this screen. A message, on which an activity which has been selected in this screen is performed, would require subsequent manual authorization for the activity to take effect. A message, on which an activity not selected in this screen is performed, would be automatically authorized with the activity taking effect.
The activities that you can choose from are:
A message on which you perform an activity that requires authorization will be available for further processing only after it is authorized.
SK Arrangement
You can choose the action to be performed on the message based on the Swift Key arrangement with the receiver. The options available for choosing are:
Processing SWIFT Messages if SK arrangement is ‘Validate’ in the static messaging table:
Duplicate Advice Tracker
Check this box to track the duplicate advices. When an advice is duplicated or regenerated, the word ‘Reprint’ appears over the advice.Generation of MT999
Saving the record
After you have made the mandatory entries, save the record. This record should be authorized before the End of Day process (EOD) is run.
Click ‘Exit’ or ‘Cancel’ button to return to the Application Browser.
You can maintain message types in Oracle FLEXCUBE through the ‘Message Type Maintenance’ screen. To invoke ‘Message Type Maintenance’ screen, type ‘MSDMSTYM’ in the field at the top right corner of the Application tool bar and click the adjoining arrow button.
You will need to capture the following information in this screen:
Module
Specify the module for which you are maintaining message types. The adjoining option list displays all module codes available in Oracle FLEXCUBE. You can select the appropriate one.
Message Type
Specify the message type for which SWIFT codes can be maintained.
Description
Enter a brief description of the message type.
Priority
Specify the priority in which a message is to be sent is displayed. You have the option to change the priority. To change the priority specified for a message, click the button marked ‘Change Priority’. Thereafter, select an option from the option-list that is available for this field.
SWIFT Message Type
Indicate the SWIFT message type in which the free format message should expressed. For the following message types in BC module, you need to indicate the SWIFT message type as MT999:
Note
NEFT and RTGS message types will be factory shipped which are available as Swift message type. These messages will be available only for PC module.
Following are the NEFT and RTGS message types generated:
Message Type |
Description |
NEFT / RTGS Message Type |
CUST_PYMT_RIND |
RTGS Customer Payment Request |
R41 |
BANK_PYMT_RIND |
RTGS Interbank Payment Request |
R42 |
DR_NOTIFICATION |
RTGS debit notification |
R43 |
CR_NOTIFICATION |
RTGS credit notification |
R44 |
STLMNT_NFTN_RBI |
RTGS sender settlement notification |
R09 |
STLMNT_NFTN_PI |
RTGS PI Response |
R90 |
CUST_PYMT_NIND |
NEFT – Incoming Payment Message |
N02 |
RETURN_TRN_RBI |
NEFT - Message for transmitting return transaction details |
N03 |
DR_MSGS_NIND |
Outward Debit Messages from NEFT Branches |
N06 |
RETURN_TRN_NBRN |
Return Transaction from NEFT Branches |
N07 |
REJECT_TRN_NIND |
NEFT - Transmission of Rejected Transactions at NEFT Service Station to Bank Branches |
N09 |
CREDIT_ACK |
Credit Acknowledgement Message for N02 and N06 |
N10 |
ACK_MSG_SFMS |
Acknowledgement message from SFMS |
F20 |
NEG_ACK_MSG |
Negative acknowledge message from SFMS |
F25 |
NEG_ACK_SUSR |
Negative acknowledge message from SFMS User |
F26 |
ACK_MSG_BKAPI |
Acknowledgement message from Bank API |
F27 |
Generate at input
Check this box to indicate that this message is to be generated at the time of input of the contract, and not after authorization.
Show in product
Check this box to indicate that this message will be available in the product to be maintained against a particular event.
Select a message/ advice and click ‘View’ button to view the complete message/advice. The system will display the following details in a new window..
You can view the following details:
You can query for tag descriptions for SWIFT messages using the screen ‘Swift Tag Maintenance’ screen. You can invoke the screen by typing ‘MSDMSGTM’ in the field at the top right corner of the Application tool bar and click the adjoining arrow button.
The screen is as shown below:
Specify the following fields:
Swift Message Type
Specify the swift message type. The adjoining list displays a list of message types maintained in the system. Choose the appropriate one.
Description
The system displays the message description.
Tag Name
The system displays the tag name.
Description
The system displays the description.
Tag Option
Lines
The system displays the number of lines required for the tag.
Sequence
The system displays the tag sequence number.
Repeatable
Indicates whether the tag is repeatable or not.
All Options
Indicates all options.
Sequence Name
Specify the sequence number.
Note
Swift message tag descriptions are factory shipped. However, it can also be maintained using this screen.
You can view the SWIFT messages and tag descriptions using the ‘Message Preview Browser’ screen. You can invoke this screen by typing ‘MSDMSPRV’ in the field at the top right corner of the Application tool bar and click the adjoining arrow button.
You can search for the messages based on the following parameters:
Module
Specify the module. The adjoining list displays a list of module names maintained in the system. Choose the appropriate one. This is applicable only for the following modules:
Contract Reference
Specify the contract reference number. The adjoining list displays a list of reference numbers maintained in the system. Choose the appropriate one.
Once you have set the search parameters, click ‘Execute Query’ button. The system displays the messages that satisfy the search criteria.
From the ‘Message Preview’ screen, you can print a message/advice using the ‘Print’ button. Select the message/advice and click ‘Print’ button to print the message.
You can maintain a specific message type to be associated with account opening event class.
The Events Class Maintenance screen is as shown below:
Specify the following details.
Module
Specify the module as ‘DE’.
Message Type
Specify as ‘ACC_OPADV’.
For further details, refer the section ‘Maintaining Message Types’ in this User Manual.
You can specify a format for this message using the ‘Advice Format Maintenance’ screen. Then you can associate this message to the event class maintained for account opening.
Refer the chapter Maintaining Advice Formats in this User Manual for details about format maintenance.
The system will support the following RTGS payment messages:
Sr. No |
Network (from Product) |
Message Type (Outgoing /Incoming) |
Product Type (from Product Category) |
Transfer Type (from Product Category) |
Message Name |
Message Description |
1 |
RTGS |
Outgoing |
Outgoing Payment |
Customer |
R41 |
This message will be generated for outgoing payment contract to customer using RTGS product. |
2 |
RTGS |
Incoming |
Incoming Payment |
Customer |
R41 |
This is a Incoming RTGS Payment to customer |
3 |
RTGS |
Outgoing |
Outgoing Payment |
Bank |
R42 |
This message will be generated for outgoing payment contract to bank using RTGS product. |
4 |
RTGS |
Incoming |
Incoming Payment |
Bank |
R42 |
This is a Incoming RTGS Payment to Bank |
5 |
RTGS |
Incoming |
Reject of Outgoing Payment |
Customer |
R42 |
This Message is for a return
of our Outgoing Payment- If the tag 7495 contains /RETURN/
and outgoing payment reference number contains (for instance, :7495:/RETURN/ |
6 |
RTGS |
Incoming |
Bank |
R42 |
and outgoing payment reference number contains (eg: :7495:/RETURN/ |
7 |
RTGS |
Outgoing |
Reject of Incoming Payment |
Bank |
R42 |
This message and transaction will be generated when authorizer rejects the incoming payment of bank |
8 |
RTGS |
Incoming |
Incoming Payment |
Bank |
R44 |
Credit Notification. Refer the Debit/Credit Notification section for detail of this message |
9 |
RTGS |
Incoming |
Outgoing Payment |
Bank |
R43 |
Debit Notification. Refer the Debit/Credit Notification section for detail of this message |
10 |
RTGS |
Incoming |
Workflow |
R09 |
This is a return message for our outgoing payment received from the RBI. This is only the Ack/NAck message for outgoing payments. If it is Ack message then system will update message status as Fully Completed (PD). If it is NAck message then system will reverse the corresponding outgoing payment contract and the message status will be updated as Process Reversed (PR) |
11 |
RTGS |
Incoming |
Workflow |
R90 |
This is a return message for our outgoing payment received from the PI (Participant Interface). This is only the Ack/NAck message for outgoing payments. If it is Ack message then system will update message status as Partially Completed (HD). If it is NAck message then system will reverse the corresponding outgoing payment contract and the message status will be updated as Process Reversed (PR) |
RTGS Debit and Credit Notifications
Debit Notifications are incoming messages from RBI generated to indicate that a debit has been applied to a participants settlement account by the transaction initiated by RBI. The message format is R43. This notification will consist of debits in the settlement account initiated by RBI only.
Credit Notifications are incoming messages from RBI generated to indicate that a credit has been applied to a participants settlement account by the transaction initiated by RBI. The message format is R44. This notification will consist of credits in the settlement account initiated by RBI only.
The system will support the following NEFT payment messages:
Sr. No |
Message Type (Outgoing/ Incoming) |
Message Name |
1 |
NEFT |
Outgoing |
Outgoing Payment |
Customer |
N06 |
This message will be generated for outgoing payment contract to customer using NEFT product. |
2 |
NEFT |
Outgoing |
Customer |
N07 |
This message will be generated for the return of incoming payment. This message will be generated when authorizer rejects the incoming payment from the incoming authorization queue or repair queue. The product category for this return of incoming payment transaction will be picked up from the product category of incoming payment |
3 |
NEFT |
Incoming |
Incoming Payment |
Customer |
N02 |
This is a Incoming NEFT Payment |
4 |
NEFT |
Incoming |
Customer |
N02 |
This Message is for a return of our Outgoing Payment- Check the Related Reference Number tag in the message. If the field is there then it is a Return of Outgoing Payment |
5 |
NEFT |
Incoming |
N03 |
This Message is from RBI for a return of our Outgoing Payment- There are two Possibilities of this Message - it can be a Reject of the Outgoing Payment or a Reschedule Message - to Find out whether it is a Reject message - Check the Related Reference Number and Reject Codes - if the Reject code doesn't fall into the Reschedule list then it is a reject of Outgoing Payment - otherwise Reschedule Message and the message status will be updated as Rescheduled(RS) |
6 |
NEFT |
Incoming |
Workflow(Reschedule) |
N03 |
This Message is from RBI for a reschedule of our Outgoing Payment- The reject code type of this message will be ‘Reschedule’ - If it is a Reschedule message then system will update only the message status of the contract as Rescheduled (RS). This reschedule message normally will be coming in during the day. Our scheduler will pick up this message and resend it to network for next schedule |
7 |
NEFT |
Incoming |
Customer |
N09 |
This Message is from SFMS for a return of our Outgoing Payment- There are two Possibilities of this Message - it can be a Reject of the Outgoing Payment or a Reschedule Message - to Find out whether it is a Reject message - Check the Related Reference Number and Reject Codes - if the Reject code doesn't fall into the Reschedule list then it is a reject of Outgoing Payment and message status will be updated as Processing Failed(XE) - otherwise it will be a Reschedule Message and message status will be updated as Rescheduled(RS). |
8 |
NEFT |
Incoming |
Workflow (Reschedule) |
N09 |
This Message is from SFMS for a reschedule of our Outgoing Payment- The reject code type of this message will be ‘Reschedule’ - If it is a Reschedule message then system will update the message status as Rescheduled(RS) and system will resend the message to the network on next working day |
9 |
NEFT |
Incoming |
Workflow |
F20 |
This is an acknowledgement message from SFMS. If this message is received then the message status of original contract will be updated as Partially Completed(HD) |
10 |
NEFT |
Incoming |
Workflow |
F25 |
This is a Negative acknowledge message from SFMS. If this message is received then system will reverse the corresponding outgoing payment contract and the message status will be updated as Processing Reversed(PR) |
11 |
NEFT |
Incoming |
Workflow |
F26 |
This is a Negative acknowledge message from SFMS User. If this message is received then system will reverse the corresponding outgoing payment contract and the message status will be updated as Processing Reversed(PR) |
12 |
NEFT |
Incoming |
Workflow |
F27 |
This is a acknowledgement message from Bank API. If this message is Negative Acknowledgement then the corresponding contract will be reversed and the message status will be updated as Processing Reversed (PR). If this message is Positive Acknowledgement then the message status of original contract will be updated as Fully Completed(PD) |
11 |
NEFT |
Outward/ Inward Credit Confirmation Message at branch |
N10 |
This is acknowledgment for N02 and N06. |
Oracle FLEXCUBE allows you to tag SWIFT messages (both incoming and outgoing) as duplicate if it identifies that the same message was sent/received earlier. Once the message is detected as a duplicate message the trailer of the message is appended to reflect this information.
Note
This is applicable only for MT103 and MT202 messages.
For incoming SWIFT messages which have a PDE trailer, system interprets the trailer information and sets aside those messages marking its process status as ‘Exception’. However, Oracle FLEXCUBE allows you to either accept or reject the message identified as a PDE, from the Incoming message browser.
For outgoing SWIFT messages, system performs certain PDE validations, to identify duplicate messages. Following are the two types of PDE validations that the system performs:
Hash Value Based PDE Validation
System calculates the hash value of a message when the message is generated and stores it in a data store. System then compares this value with the hash values in the message log to identify duplicates.
Note
System performs hash value validation on messages as a mandatory check.
Message field (Tags) Based PDE Validation
Tag based PDE validation is performed only for Customer Transfer (MT103) and Bank Transfer (MT202) messages. You can decide the tag value based on which system needs to perform the validation.
Note
Tag value validation is done only if you have selected the ‘PDE Functional Validation’ option in the ‘Messaging Branch Parameters Maintenance’ screen.
System uses the following fields to compare and identify whether a message is a PDE or not. This data is factory shipped.
Customer Transfer MT103
Message Tag |
Option |
Tag Description |
50 |
A, K, F |
Ordering Customer |
32 |
A |
Interbank Settlement Amount |
32 |
A |
Currency |
32 |
A |
Value Date |
57 |
A, B, C, D |
Account With Institution |
59 |
A or No letter |
Ultimate Beneficiary |
Bank Transfer MT202
Message Tag |
Tag Description |
Field Position |
32 |
A |
32 |
A |
Currency |
32 |
A |
Value Date |
58 |
A or D |
Beneficiary Institution |
Note
You can also choose not to use any of the above tags for comparison. Along with the above fields the Sender and Receiver BIC are also used for procedural validation.
The system detects the messages (Incoming/Outgoing) as PDE messages by performing the validations discussed in the above section. The Incoming and Outgoing PDE messages are processed by the system in the following manner:
In the case of incoming messages, EMS picks up the incoming messages and inserts it into a data store. If the incoming message has a PDE trailer (message contains the text ‘PDE:’} then the system will mark the process status as ‘Stopped due to PDE’. After due validations, you can release the message from the incoming PDE message queue. Once these messages are accepted it will continue to get uploaded as a normal message. If the PDE trailer is NOT present in the incoming message, then the message upload will continue as normal.
In the case of incoming messages with a PDE trailer, the ‘PDE Flag’ check box in the ‘Incoming Message Browser’ screen will be checked.
For more details on the PDE indication of an incoming message in the Incoming Message Browser, refer section ‘Viewing the details of an Incoming Message’ in ‘Processing Incoming Messages’ chapter of this User Manual.
In the case of outgoing messages you can decide to do any of the following if the system detects a message as a duplicate, based on the PDE validations:
System displays an override when it finds a message to be a duplicate one. In this case the message is parked in the PDE queue and you can either opt to release the message without the PDE trailer or else release it with the PDE trailer. If you opt to release the message with the PDE trailer then the message is appended with PDE, else the message is released without PDE. You can also choose to reject the message. In this case the message status will be changed to ‘E’ (Exception) and this will not be picked up by EMS (Electronic Messaging System).
Due to message size restrictions in Oracle FLEXCUBE, sometimes a single message is physically split into multiple parts and each one is stored in a distinct record in the outgoing message data store. A message is marked as ‘PDE’ if ALL the split messages are found to be duplicates.
Note
All the messages in the PDE queue (Incoming and Outgoing) are completely processed by EMS prior to initiating EOD operations.
For more details on outgoing messages in PDE queue refer section ‘Processing Outgoing Messages with PDE Trailer’ in ‘Processing Outgoing Messages’ chapter of this User Manual.
You can maintain agreement with the sender/receiver BIC through the ‘Agreements with Sender/Receiver BIC Maintenance’ screen. You can invoke the ‘Agreements with Sender/Receiver BIC Maintenance’ screen by typing ‘ISDCCYRS’ in the field at the top right corner of the Application tool bar and clicking the adjoining arrow button.
You need to capture the following information in this screen:
BIC Code
Specify the BIC code. The value entered here must be a valid BIC code in the system with the options Generate MT102, Generate MT102+ and Generate 101 selected.
Message Type
Select the message type from the option list.
Direction
Indicate whether the BIC-currencies amount maintenance is for incoming or outgoing or both type of messages. You have the following options here.
Product for Consol Debt
Specify the product for consolidated debit entry to ordering customer. This can be specified for incoming MT101.
No. of Transactions per Message
Specify the total number of transactions for each message (MT101).
Cutoff Incoming
Specify the cutoff time in hours and minutes for the incoming messages.
Cutoff Outing
Specify the cutoff time in hours and minutes for the outgoing messages.
The details displayed here depend on the direction specified. They are used for MT101, MT102 and MT102+.
Incoming MT101
If the message is an incoming MT101, on receiving the message the following checks will be made before uploading the transactions.
