18 Loss Prevention
XBR is a loss prevention tool that integrates with Reporting and Analytics. If XBR is enabled for your organization, you can set thresholds to identify suspicious trends and transactions that might require corrective action. For example, you set a discount threshold percentage of 15 percent. The system indicates a cashier routinely applies discounts significantly above the threshold.
