To perform manual item alignment, in Reporting and Analytics, clickAdmin, click Warehouse, click Alignment, and click the type of database item. If the organization is configured to match family group or major group, you must perform alignment in the order of Family Group, Major Group, and then Menu Items.
| I want to | Then do |
Filter the list of master items. |
Click Options. |
Align an item. |
Change the alignment of an item. |
Designate an aligned item as an alias. |
If the alignment rule allows menu item aliasing:
Unalign an item. |
Merge master items. |
Designate an unaligned item as a master item. |
Configure alignment rules. |
Run the alignment process immediately. |
Click Run Alignment. |
Parent topic: Item Alignment
