13 Manager Communication
The Reporting and Analytics Manager Log is a location-based communication tool for managers. Use the log to add entries and notes for other managers at the location. For example, you are a morning manager at your restaurant and you notice you are low on eggs. Add a to-do log entry for the evening manager to order more eggs. After the evening manager orders the eggs, the evening manager can mark the to-do entry as complete. You can also use the Manager Log to add notes on daily operations.
